Key Fob Repair
I removed the circuit board a few days ago while troubleshooting an intermittent "lock" button. Circuit board hung up a bit when reinserting and I just applied enough pressure to get the board inserted. Yep, key fob would no longer work in the ignition switch (Keyless-Go worked fine). Confirmed no LED flash from the nose of the key fob using my cell phone camera. Removed the board and see the infra-red LED is no longer on the front of the board. Fortunately, the LED was still in the shell. I had to use magnifying head loupes to see the solder on the LED; once I could see the solder remains, the LED could only be installed one way. Used a clip to hold the LED in place, applied heat and solder, and confirmed the key once more works in the ignition switch.
So...be gentle!
