2009 W211 E63 Drivers keyless door handle not working
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
The keyless go feature on the front left ( Drivers side ) door handle does not work, but all the other doors open and lock fine without the key.
I found a YouTube
, where the guy attaches two 300ohm resistors inside the handle and replaces the switch. Was curious if anyone tried this on their car and if it works for all W211s?
Wanted to fix it this way as opposed to getting a new handle entirely, which cost about $200 from what I've researched so far.
I found a YouTube
Saurabh914 (01-17-2021)
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
You need to buy a new door handle, as the electronic inside the door, have corrosion, and that is your issue. I have replaced all four door handles over the years.
MbBiturboFan (01-17-2021)
2009 E63, 1984 500SEL AMG, 1984 500SEC AMG Widebody
Three of my four handles don't work - the Driver door handle was replaced by the prior owner about 5 years ago. I have all four new ones from MB in my body color that i bought over the past 2 years (lucky I have a rare body color - MB still had them in stock).
My brother has a W124 E320 Cabriolet. Over Christmas, I detailed his car and sprayed the soft top with RaggTop water repellent spray. I was thinking of taping off the new handles that I will install soon and spray the handles with RaggTop to give them a modicum of water repellent ability. Not sure if it will help, but will try. Certainly open to other ideas.
Wonder if the frankenstein resistor fix is purely because the resistors burnt out or something. Wonder if there is a way to tell as you said if its broken due to corrosion or something else.
Was also curious if I could swap the rear left handle for the front left, but I think they are slightly different shape.
Wow, really? I already bought the 475 and 300 ohm resistors, along with the switches. In total was $5, so a bargain. A new handle costs upwards of $200. I am not sure if its personally worth it, would just like everything functioning.
I'm no electronics wizard, so I just replace them. But, I do have friends at the dealership and I get parts at a reduced cost.
