Turning Signal Issues
I just bought my 2005 E55 AMG and I'm loving it but currently, I'm having issues figuring out what's up with my passenger turning signal. I replaced the bulb and nothing, I check the socket and nothing. I made sure the light and socket were working by putting it in the driver's side turning cavity and it worked perfectly fine. I was wondering if the 2005 E55 had a fuse or relay that controls it so I can check on those as well. Everything is fine about the car besides this.
'99 and '05 E55 AMG
A short, an open, or an issue with the front SAM, less likely an issue with the turn signal module on the column. Use Xentry and WIS to diagnose; you've already done the easiest part.
