Traction control cheats
On certain GT-R's, you can disengage the front driveshaft in such a manner to make the car straight up RWD. It would be really great if someone knows if there is something like that for the Electronic Nanny on the E55.
With late model 2004 & up, put ignition on stage two & press the reset (R) button five times within 3 seconds of switching ignition on then scroll up the sub menu & select dyno mode. This should disable traction control, I've tried it on a 2004 E55 & SL55.
Try it out, let me know how you go.
Hope you can have your fun..
