M113k S/C bolt?
Old Apr 18, 2021 | 11:37 PM
Fidel_CashFlow's Avatar
CLK55
M113k S/C bolt?
I'm trying to lift a M113K out and need help figuring out the right bolt that goes on top of the S/C in order to get a hook there.
Old Apr 19, 2021 | 10:41 AM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Not sure on those bolt holes, but there are hook points at the back of the SC on either side, so you can attach to there and then around something on the front. I've used those studs on the front of the SC with success as a chain link fits nicely onto them.
Old Apr 19, 2021 | 12:46 PM
CLK55
thanks man!
Old Apr 19, 2021 | 02:21 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I think they are M12 x 1.5 Either that or 14mm. I know I've used a set of wheel bolts to lift the engine out, just can't remember which car the bolts were off!
Old Apr 20, 2021 | 12:44 AM
CLK55
that was exactly it!!! They are M12 x 1.5. I was lucky enough to have my wheel bolts from my CLK still from when I converted it to lug nuts
Old Apr 21, 2021 | 01:31 PM
coupesedan's Avatar
CLS55
you can break them off easy
i found out mine was jb welded back together
