Can't find part number for coolant pipe
2115002372
Thanks,
In my case, I used the rubber covered hose clamps from the old pipe to insulate the new one from having the same issue. It is a bit of a bear to reach everything to get the old pipe out if you haven't already done it. 90 Degree short length tools would be handy, as there is very little clearance between the radiator abd the accessory belt systems. I believe the hose clamp was a torx if memory serves. May possibly have been a small metric like a 10 mm. If you have really big hand/forearms, it's not going to be much fun.
