F33 Rear prefuse box drain battery
Old Aug 10, 2021 | 12:27 AM
2001cl500w215's Avatar
W210 AMG and W211 AMG
Hello All,
This is my first post. Please help, My 2003 E55 rear trunk fuse #85 (5 Amp) (red circle) is draining my new battery. Batteries and Alternator is good. Got 5.2 mA (prefuse box) when vehicle in sleep mode. All hood and trunk latches closed and all door sensors pressed in. If I removed the fuse #85 voltage is normal and fire up and get 13.9-14V when warm up the car in the morning. But get SRS light but drive normal. See image for more info.
check continuity get beeps in yellow removed fuse 85 (red circle), car start normal but get SRS light.
Old Aug 10, 2021 | 08:44 AM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Originally Posted by 2001cl500w215
Hello All,
That fuse seems to be for telephone in the center console and voice control. Something with that is not going to sleep and causing the draw. Have you added any electronic devices to the car? Not sure how that might intergrate with SRS. Other's will likely chime in.
Old Aug 10, 2021 | 09:07 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I was thinking it could also be an SOS issue. Aren't those known to go crazy and drain the battery or did I make that up? I thought SOS functionality lived with the SRS module.
Old Aug 10, 2021 | 09:22 AM
All factory no after market electronics. I noticed when the car in sleep mode the CD/Cassette is making noise. So I pulled the radio, driver and passenger fuses on the interior driver side panel and still drain the battery but next morning seeing "Battery Protection Coven. Functions Temporarily Unavailable" message. Swap fully charge battery and message goes alway.
Old Aug 12, 2021 | 10:14 AM
Can anyone please check the draw the fuse circle in red in their vehicle sleep and none sleep mode and report so I can compare? Please help
Old Nov 30, 2025 | 02:31 PM
mcanix's Avatar
2003 E55 AMG
Did you ever get anywhere with this?
