What is this sound?
Old Sep 12, 2021 | 12:07 PM
MartinWake's Avatar
CL55
What is this sound?
Hello guys I have a CL55 amg and it has been making this high pitch sound. It only happens when the car is really warmed up, You can hear it in 1st gear the most but also in other gears too.
Since my car has ABC I thought it was the Pulsation Damper at first but I have since replaced that and it did not change anything. It sounds to be transmission related but my car still shifts like it has always.
The transmission fluid is also on the max level and is not dirty. Any ideas what it could be? I will post a video link down below with a sound clip while I am in park.
Old Sep 12, 2021 | 04:55 PM
SICAMG's Avatar
2005 e55 AMG
Old Sep 12, 2021 | 05:41 PM
E55Greasemonkey's Avatar
This place is a joke.
remove both belts and rev it again (briefly) like in the video.
Old Sep 12, 2021 | 05:58 PM
MartinWake's Avatar
CL55
Originally Posted by SICAMG
Why did you start another post ?
This video is much better so easyer to hear it. Sounds like your torque converter is starting to go. I would stop driving it and start diag. process before it takes out the entire transmission with metal. Have you dropped the pan yet to look ?
Well I think I know what it is now (check video below)
I was driving it to the gas station and it felt harsh. I was able to make it home when it put itself in another gear.
It finally threw a check engine light with this code: p0730
Now the question is what could it be? I talked to one mechanic on the phone and he says it is the conductor plate but I have also read about a wire getting soaked in trans fluid?
Video:
Old Sep 15, 2021 | 08:52 PM
MartinWake's Avatar
CL55
Alright I took off the pan and I do not see any flakes of metal. The filter is also clean. Could it just be the conductor plate now? It did every symptom of that.
Video 1:
Video 2:
Old Oct 13, 2022 | 08:50 PM
Slow AMG's Avatar
2004 E55 AMG, 2004 E320, 2004 E500 (sold), 2007 E550 (sold)
Curious - did you ever find out what the true culprit was? My W211 E55 with the M113K/722.6 is having the SAME exact issue with the same code.
Old Oct 14, 2022 | 07:25 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
You could try an adaptation reset as in the video, but it sure looks like it points to the conductor plate. If you are swapping it out, also replace all solenoid O-rings while you are in there! I didnt take this into consideration, but these rings tend to get hard and dont seal that well, leading to jerky motions etc.
Old Oct 14, 2022 | 05:50 PM
Slow AMG's Avatar
Just order up the full conductor plate kit now, thanks man.
Searched around a bit and seemed most common was folks having transmission fluid wick up into the TCU due to faulty pilot bushing - but my TCU is dry, so must be the conductor plate. Good call on the o-rings too, was about to overlook that!
