E55 Vs M5 Dinan
I would doubt that the GT will run 11.2 all day around here. Not underestimating the car itself, but those numbers quoted by the pro test guys are never reality numbers.
Least around here. However, you'll find that out once you cut the leash.
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
2000 E430 Sport
AMGB, when the temperature is hot outside, the air is less dense, and there is less oxygen for a given volume. The opposite is also true, and therefore, cars typically perform better when it is cooler outside. This effect is amplified with boosted engines.
