Anyone know why AMG went from 8 pot calipers for the E55 P30 to 6 pot for E63?
So your car has the 390mm Rotors? Is it possible there are two different brackets with the same part number?
The calipers have the crossover line so they are the older version caliper. But the dimensions are the same.
I believe the brackets that are in that eBay listing (post #17) are for 360mm Rotors and 19.7661.05 is for 390mm Rotors.
They share the same 110mm mounting distance on the steering knuckle.
Let’s confirm machild’s rotor size for further clarification.
Not sure about 212’s but if you run 390mm rotors you may need 19” wheels.
Either Guido had a bad Monday or it’s the same bracket reused which gives different distance depending on knuckle it's used on. It (both 19.7661.05 brackets) look identical.
MB may have repurposed it and took off the “390”. It wouldn't be the first time. I think that is the same bracket they used on R230
I also think the bracket on eBay is correct too, perhaps a later “AMG blessed” design. Maybe different bolt size on steering knuckle? But they look the same size…
20.9747.47 is clearly marked 212 chassis with 360mm brakes and looks identical to the one on the 360mm caliper/bracket in your attached Centric document (19.7661.05). Spacing and height all look correct. The difference being they are pictured with the early caliper with the crossover tube. Whereas 20.9747.47 is coupled with the later caliper without crossover tube. But one would think they all share that 256mm distance to bolt the caliper to the bracket.
Come back and let us know when you get them....
Haha, Or if we have to start a go fund me page
I believe that is the spacing for adapter 20.9747.47 for the W218, W212 etc…
though I haven’t verified that. But going off the drawing and visually it looks like a shorter distance. 110mm would be about right.
Also look at the casting number for caliper, it’s 20.A495.04 & 20.A495.03 which is the same across the line on C190’s W218, W212 etc…
Caliper casting number for the R231 W221 is different. They are 20.B282.05 and 20.B282.06
It’s what got me thinking about bore sizes, but I think it’s more about hose placement.
W218/212 caliper&adapter
people do a similar upgrade using a brembo caliper from a genesis coupe which uses a 340mm from factory, but due to the caliper being closer to the knuckle on the honda you end up using a 320mm rotor from a nissan rogue (reason im not doing the genesis coupe brembos is the genesis coupe never released in my country (australia) and importing a 10kg caliper gets expensive)
anyway i was thinking of getting a ''test'' caliper from a w222 (like pictured below) and bolting it on and doing measurements to see what will work, im aware i will have to swap the left and right around due to the bleeder nipple and caliper position but anyway should be a fun little project
The similar appearing 6 piston calipers used on the 212/218 bodied cars actually have smaller pistons at 32, 34, 38 for a total sqaure area of 11,379mm - the same as the 8 piston calipers used on the E55. Hope that helps.
the brackets and calipers are not cross compatible. the W211 and W219 calipers and bracket union uses an M10 bolt but the W204/W212/W218 caliper to bracket union use an M12 bolt.
The rear calipers on the 212's have piston sizes of 32mm & 30mm compared to the original 211's of 30 & 28. So, not only is there more leverage with the larger diameter 212 rotors but more clamping with larger overall piston area. Your thought of increasing the rear bias may well be the reason they went the route of decreasing the front caliper poiston area on the 212's.
Proper bias is important and with the 211 they moved farther toward adding more front bias when they went to the 6 piston caliper.
The brackets and calipers are not cross compatible. the W211 and W219 calipers and bracket union uses an M10 bolt but the W204/W212/W218 caliper to bracket union use an M12 bolt.
Since it has been some time and I don't remember if I have mentioned this, to use the 212 rear calipers on the 211 platform you will need to make a couple of small changes to the caliper and the brake line connection to the caliper. If you already know that I won't type it out here again, but if you you are not aware of it then let me know and I can go over it for you.
The other issue is the way the flexible brake line connects to the caliper. The correct installed situation has the brake hose connecting lower side of the installed caliper and in an upper angle. When the caliper is rotated 180* degrees around the axle line, the connection is on the upper side and not only will the brake hose not connect it iwll end up being the highest point and making bleeding very difficult. The solution is to replace the brake line hose with a banjoe fitting hose designed for a standard 10mm banjoe bolt. I can get all the spec for this conversion if you are really interested. I hope that helps, but ask if you have more questons.
p.s. - Always good to see your posts!
By keeping the caliper on it's original side and simply rotating it around the rotor it keeps the pistons in the correct orientation to the rotor rotation direction. But, that is where the other issues of bleed nipple and brake line connect come in. But these calipers are adaptable to the changes - many calipers are not adaptable as there are not secondary location of the bleed nipples avaliable.
I hope this helps.
This info is based on a very quick look around. There may be a rotor that meets the spec's and allow the caliper to be mountied in the original location without modifiction. But, this could/should/may allow to use the 212 caliper without moving the bleed nipples or come up with a banjoe connection setup.
