3.06 Gear swap compatibility
When I put my whole suspension back together after renewing every bushing, including those of the subframe, I had already attached the entire rear subframe with the arms all torqued to the carriers before installing the Diff! Oops. I ended up having to loosen up my passenger side Carrier from the Lower torque arm, as I had not yet installed the UPD Toe Arms, then insert one axle in the driver side hub, then insert its inner end into the Diff whilst it was on my Tranny Jack floor side, then Installed the inner end of other axle into the Diff, raised the Diff on the Jack while lining up the outer axle with the Hub using one foot to push the Carrier outwards to allow the angle to line up the axle with the Hub! Once seated, then I raised the Diff to install. You gotta make sure each axle is then solidly seated on the inner side. Torquing up those rear Diff Bolts are Not easy either as there isn’t enough space between the subframe and the Spare Tire Tub to get a ratchet on. So I had to unscrew the Rear Subframe bolts, thereby having to wire brush each tunnel and remove newly applied Blue locktite, to allow me to have enough room to get a full sized Torque Wrench on those bolts! And even then, because I had only so much elevation of the diff to work with (ie-Not enough!) I could only get about 120Nm of torque on those puppies! Just shy of the IIRC 160Nm??
In your opinion would it be a better option to mate Cherokee/Durango gear to e55 or us a bolt in amg diff?
Sorry, I don’t know if the C55 diff will fit an E55. We bought the C55 diff for a different project and I have no knowledge of what fits what. I’m sure there are some other guys on here that have more experience with this that might be able to help.
