600+ whp E55
Mods:
77/180 stack (pinned)
Hellcat throttle body
Eurocharged ECU
TJ Merry TCU
LT Headers
650cc injectors
Forced Induction Interchiller, Stage 2
3/4" Intercooler lines
Single Stage Intercooler
Dual CWA100 Intercooler Pumps
5 gallon trunk tank
Built engine by Dan Benson, ARP head studs
Wavetrac differential
Driveshaft Shop axles
Dyno done on 100 octane
D.A.: -700 to -800
66 degrees ambient inside dyno room, but it was 45 degrees outside.
Ignore the 260, that was a bad pull. The dyno pulls shown are one pull after each file revision until we got close to target AFR. You can see the power increased with each revision. It is very consistent.
Caution: To run this setup, your cooling and fuel must be 100% in check.
She will go to the track when they open back up mid-January. Our tracks closed in early December this year and my dyno tune was on Dec 20th. All closed for the year unfortunately.
so the car is making over 700 at the engine.
