Vaico
Old Feb 22, 2022 | 11:55 PM
user 5580820382's Avatar
E55
Vaico
Hey guys about to change water pump. Fcp euro has genuine mercedes for double the price of the Vaico unit that says oem. Anyone have any experiences with this brand
Old Feb 23, 2022 | 06:26 PM
E55
Nobody??
Old Feb 23, 2022 | 10:11 PM
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
I use RockAuto almost exclusively for sourcing parts. For the water pump on the M113K engine, they only carry one quality manufacturer and it is Vaico. Vaico is a division of Vierol, a german auto parts manufacturer. I have not used that manufacturer, but if you are buying it through FCP and they are providing you a life time warranty, they probably aren't selling junk. BTW, it is listed on RA at $130.79. Good luck.
Old Feb 23, 2022 | 10:13 PM
E55
Thanks for the reply I guess I'll go with Vaico
Old Feb 23, 2022 | 11:16 PM
rjrzwhips's Avatar
2003 E55
I recently replaced my water pump. I went with URO brand. Please keep in mind that the water pump is interchangeable with non amg e class models. A few of the holes on the water pump housing are not tapped. The non amg models have no need for the second tensioner specifically for the supercharger belt. The oem bolts for the supercharger tensioner are self tapping so pretap the bolt onto the new water pump housing before installing to make installation easier
Old Feb 23, 2022 | 11:43 PM
E55
Thanks.foe.the info
Old Jun 26, 2023 | 07:37 PM
HubTraum's Avatar
S211 E55
So which pump you got?
I‘m tempted to buy a ÜRO or a Vaico pump... I even could get my hands on a Quinton Hazell unit...
What‘s your recommendation?
Any long term experiences?
best regards
Old Jun 26, 2023 | 09:04 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
best regards
dont get URO. Parts quality ranges from great aftermarket fixes to common BMW problems, they make a decent valve cover for BMW actually. abhorrent unsafe trash of bushing and flex discs due to subpar rubber. The control arms they offer for 911's fail within months. If you keep it to plumbing, small parts, fan blades, you're actually ok with URO.
VAICO is fine, I exclusively use their transmission filter kits.
I'm also warning you, water pumps suffer the most from parts quality defects because of the accuracy needed in casting, the bearings, and even the hose retention on the clip. You want to be sure on this.
Be kind of quick, theres a parts shortage on everything lately on my side.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 26, 2023 | 11:26 PM
E55
I went with vaico no issues now been around 1yr .
Old Jun 26, 2023 | 11:45 PM
SPONSOR
if it's gonna break, it'll break right away. you're going to be fine
URO, Rein, the ghetto stuff on Rockauto under the economy section, when they go they go immediately. Horrible bearing noise, blows coolant through the impeller shaft, wobble, the hose will get ejected because of the casting imperfections or the clip being defective.
__________________
Old Jun 27, 2023 | 12:46 AM
HubTraum's Avatar
S211 E55
Thanks a lot for the input!
The only reason searching for options is to avoid Mercedes prices...
Waterpump for m113k is ~450,- € for the rebuilt unit (with ~50,- € core charge) or ~500,- € for a new unit (which should be NLA now - last time I asked there were 5 available in total...)
So as a german it‘s cheaper to order overseas and probably faster, too (including customs etc. ...)
I even asked a local machine shop which rebuilds waterpumps (for older cars) ... ~420,- € for the rebuild of my old unit... no thanks...
Vaico, FEBI, HEPU are NOT available anymore in GER...
Vaico in eBay ~ 250,- $ (+shipment +GER ~19% tax +3% GER customs)
Quinton Hazell ranging from 65,- £ (+shipment +GER ~19% tax +3% GER customs) up to 250,- €...
ÜRO ranges from 150,- $ (+shipment +GER ~19% tax +3% GER customs) to 250,- €!
Therefore I think I will buy a original + core charge at F C P (beacuse Vaico is on backorder 😆 ) which will cost only a little over 1/2 of the price compared to the dealership 🤪
Old Jun 27, 2023 | 01:25 AM
SPONSOR
https://www.autohausaz.com/pn/MB-113200010180
__________________
Old Jun 27, 2023 | 02:36 AM
HubTraum's Avatar
S211 E55
Sadly they don‘t ship international...
Best regards
Edit:
they do!
BUT
AutohausAZ
107,- $ shipping cost?!
total of 293,- $
F C P
48,- $ shipping cost
total of 265,- $
Old Jun 27, 2023 | 08:28 AM
machild's Avatar
Top Answer: 1
RockAuto.com shows one in stock at $150. They do ship and/or have internationally distribution but you will have to check on the shipping to you.
Old Jun 27, 2023 | 11:26 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Im also in the EU and basically could only find a couple of options on the known sites. Quinten Hazell being one of them indeed
Dealer asked for €550 for the OE waterpump, QH is half of that...
Old Jun 27, 2023 | 01:58 PM
@HubTraum
Triscan / https://www.ebay.de/itm/374703885613 / €70
Quinton Hazell / https://www.topersatzteile.de/herste...azell/11944042 / €220
FAI / https://www.ebay.de/itm/314504946692 / €160
I have no idea what the best choice would be for us...
Old Jun 27, 2023 | 03:15 PM
HubTraum's Avatar
S211 E55
@nd-photo.nl
I think this order should be reasonable since pricing is not that much apart...
- Mercedes (from US.)
- HEPU (if you can find one - they look like the original but „missing“ the complete part #)
- Vaico (from US.)
- QH / ÜRO / Triscan (if you have to repair it now or want to sell the car)
best regards
PS: my pump appears to be the Original one - if so it lastet 18 years and ~ 380k km 😎
Old Jun 27, 2023 | 04:50 PM
I also have the original one afaik, also 18 years old but "only" 196k km
Thanks for the list!
Old Jun 28, 2023 | 06:45 PM
@HubTraum where you also referring to this one?
Vaico: https://www.ebay.de/itm/125773861045
Old Jun 29, 2023 | 01:57 AM
HubTraum's Avatar
S211 E55
Yes but No 🤣🤣🤣
eBay #166165540569
10$ cheaper 👍🏻
Old Jun 29, 2023 | 08:33 AM
Noice, bookmarked
Old Jul 3, 2023 | 10:14 AM
HubTraum's Avatar
S211 E55
For all interested:
Vaico V30-50074 appears to be available again in eBay or at autodoc 👍🏻
best regards
Old Jul 3, 2023 | 01:31 PM
I also noticed it, I will order it this week! I wanted to inform you but you beat me to it @HubTraum
Old Jul 4, 2023 | 06:43 AM
I ordered the Vaico yesterday for €145
Old Jul 8, 2023 | 05:54 AM
HubTraum's Avatar
S211 E55
Made in China ...
