Panoramic Roof Gear Issues
I saw online someone posted that the reason the panoramic roof gear failures are due to a bad design with the motor and its shaft over time having its shaft sliding in and out causing the gear to lose contact which eventually causes the gears to grind and wear out. If true, does anyone have a fix for this as mine recently has begun skipping gears.
