Stock Throttle Body Question
Solved: Stock Throttle Body Part Nmbr Question
solved: see post 2 for part #
Hi Guys,
My car has been throwing P0638, P0507, and P2121, these come back within a couple of minutes of clearing and has been diagnosed as having a bad throttle body.
Symptoms: ESP malfunction message, no throttle response, engine cuts off at times, rough or high idle.
Wiggling the throttle body cable while the car is running causes it to idle rough and then either it cuts off or idles above 1000 rpm
The part number on the original throttle body is: A 113 141 03 86, this is printed on the black rubber boot on the left side of the throttle body, but EPC can not find that part number for any application.
The part numbers given by EPC are:
1) A 113 141 06 25
- 015 not installed in vehicles with engine no 60 000137;
- 830 From Model year 2003 - code 803
2) A 113 141 01 25
- 016 also installed in vehicles with engine no 60 000137;
which would be the right part number for my application (2003 E55) & also would I need to get a pigtail to connect from the main harness to the throttle body.
Thank you in advance.
Hi Guys,
1) A 113 141 06 25
2) A 113 141 01 25
Hi Guys,
The part number on the original throttle body is: A 113 141 03 86 but EPC can not find that part number for any application.
1) A 113 141 06 25
2) A 113 141 01 25
1) A 113 141 06 25
2) A 113 141 01 25
The throttle body is made by Bosch and the part number is 0280750017 which cross references to A 113 141 01 25.
You will also need A 113 150 00 28, which is the pigtail connector (from throttle body to plug on harness)
