VRP Top Mount Intercooler Kits Now Available! - VRPSpeed
The best of the best! VRP Top mount intercooler kit (TMIC)
This setup has led to the lowest intake temps of any cooling setup ever tested for the M113k. On a 88* day on 21 PSI peak temps were only 95*!
Another test session with 95* ambient temperatures had peak temps of only 99*!! This is the single best and final cooling modification you will ever need!
A before after test had a vehicle start at 147* peak temps before the top mounts, and drop to 97* after top mounts!
Kit includes:
VRP Billet Surge tanks
2x Top mount Intercoolers (500HP cores)
Piping with necessary sensor port welded
Couplers
Clamps
Fittings
AIT sensor extension harness
Low profile oil filter housing
*This will require a custom intake or mushroom filter which is NOT included.
Interesting setup but price will keep many away, plus the fact that no intake solution is included with the kit.
We are working on finding another supplier for the high horsepower intercooler cores, other than the billet surge tanks thats where the bulk of the costs comes from, Without the Billet surge tanks this kit is also only $2,500 (They can be removed on the order page if you already have them)
