OG needs some headlight help and i’ve searched and searched
i bought a car in less than desirable shape and misrepresented both of the xenon lights are aimed at the floor, literally can’t see at night. i had a short on high beam and then took apart the headlights to find this.
i have fixed all the those wires with solder and heat shrink one by one.
these are the wires on projector
i can get to those (i think) but my issue is the bi xenon motor wiring
this is the bi xenon motor and…
i can’t find heat shrink thin enough to shove in there in order to ensure those don’t touch.
i do have star with development mode and id like the car to work normally but right now id kinda just like to see at night.
Yes as stated above liquid tape. You know that’s one of the many things plasti dip is/was used for prior to being the thing to use to spray emblems and cars.
good luck on the wiring. I took my E lights apart to swap in Morimoto EVOs and had the wire issues so just bought new lights. Then opened them up to still swap them out.
