Question on tb snout
I believe that’s the evap port for the fuel tank valve. I just put a c32 back together and if I recall this has an aluminum line that runs to the drivers side and goes to the evap solenoid valve. The only other port on the c32 was for the brake booster, and the W211 doesn’t have that because it has SBC and I believe that port is on the passenger side.
these are quick connect fittings push and release and push in for installation.
2005 CLS55 AMG W219 C219
Its for the brake booster if you dont have the SBC system. You can swap it out with another Mercedes piece (rubber bung for windshield), but I dont have the site/partnr here with me. I can post it later when I get home.
EVAP port sits a bit lower (see picture below)
[edit]
I found it!
https://stumptownbenz.com/simple-plu...r-vacuum-port/
[edit]
I found it!
plug for the windshield washer on a CLK320 (part number 210-987-00-45) that is the perfect size for the port in the supercharger!
UncleBenz55 (08-19-2022)
