Is M113K an interference engine?
Old Sep 9, 2022 | 11:54 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Question in title.
Old Sep 10, 2022 | 01:23 PM
chassis's Avatar
2017 GLE350 4MATIC
From the absence of valve relief on theses pistons it seems that way.
Old Sep 10, 2022 | 04:23 PM
cdk4219's Avatar
95 SL600
Yes most definitely, and It doesn’t take much deviation from stock cam timing to have an issue.
Old Sep 12, 2022 | 02:41 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Yes, that is why they have you set the crankshaft to 40 degrees after TDC when setting the cams. At that position all of the pistons are low enough to clear any valves that may be open.
Old Sep 15, 2022 | 01:43 PM
Max Blast's Avatar
NGL450 w/EORP, S550
So if your crankshaft sprocket woodruff key lets go, there will be carnage?
Old Sep 15, 2022 | 02:35 PM
JoeJErnst's Avatar
Potentially. The one key is shared by the harmonic balancer and the timing chain gear, so it's possible to shear it in half and let the balancer spin loose while still retaining the gear.
