AMG Tire Pressure..
Old Oct 12, 2004 | 11:47 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
AMG Tire Pressure..
When you open your door. What is the recommended tire pressure for your standard AMG wheels?
I just bought a set for my E500 and am wondering what pressure to put them at.
Any recommendations considering my front end weighs less?
Old Oct 12, 2004 | 12:21 PM
norb's Avatar
2009 C63 AMG
34psi all around I think. I'll check at lunch.
Old Oct 12, 2004 | 04:02 PM
enzom's Avatar
2005 E55
35 lbs all the way around.
Old Oct 12, 2004 | 05:42 PM
ATS's Avatar
ATS
It states 35 PSI inside the door or that is what you recommend?
Old Oct 12, 2004 | 07:31 PM
MB Fanatic's Avatar
4 wheels
I keep mine 35 all the way around.
Old Oct 13, 2004 | 10:22 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Hard to believe that the inside of the W211 E55 door sticker has 34 or 35 psi recommended tire pressure? Three responses and all say 34 or 35 psi?
My W210 E55 is 41 front and 48 rear per the lable inside the door.
Old Oct 13, 2004 | 11:29 AM
Vic's Avatar
Vic
Wow. That really sounds high. My 2005 indicates 35 all around.
Old Oct 13, 2004 | 02:33 PM
E55 KEV's Avatar
Veteran: Air Force
The only difference in the W210 and W211 is the rear OEM tire size.
W210 - 275/35/18
W211 - 265/35/18
Old Oct 13, 2004 | 04:44 PM
cte430's Avatar
'07 Porsche 997TT
41 front 36 rear improved handling significantly
Old Oct 13, 2004 | 08:54 PM
MelsE55's Avatar
2002 E55, Brilliant Silver/Charcoal and Grey, All option except Parktronic.
The label inside the door say one thing, the label in the fuel filler door says something else. I use 38 front and 35 rear on my W210 E55 and it seems to like it. The pressures on the fuel door are too low, it squirms around at those pressures.
Play with it and see what works. cte430 has the idea.
Old Oct 13, 2004 | 10:59 PM
tendons's Avatar
tire pressure
i happened to put in 42 front and 37 rear, inadvertently , and found the handling crisper, although a bit more twitchy. Tire rack says that pressure will probably cause increase center wear, but isn't harmful or dangerous in anyway.
Old Oct 13, 2004 | 11:14 PM
tjcMBE55AMG's Avatar
2002 MB E55 AMG
That's about what I've been running on original Pilot Sports and have 19,000 miles on them - just bought PS 2's to replace.
I didn't see any particular wear at center.
TJC
Old Oct 14, 2004 | 11:16 AM
ATS's Avatar
ATS
I had put them to 35 and 35 on both last night..
I had the Appearance package wheels which are 17 inch and they were at 30 and 32.
The new ride is A LOT harder. It now seems my comfort setting is the old Sport 2 setting.
I really liked the plushness of the old comfort setting.
Would putting these down to a lower pressure cause problems?
(Please remember I do not know that much about tires and tire pressures..)
Thanks guys..
Old Oct 18, 2004 | 07:35 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
According to Luke (Tire Rack) 42 front 36 rear - a significant improvement - see thread in the Tire Rack forum.
Old Oct 18, 2004 | 10:57 AM
ATS's Avatar
ATS
Thanks everyone for the info..
