Resonator question...
Old Oct 14, 2004 | 03:43 AM
BenzoBoi's Avatar
Super Moderator
W221
Can takin out the resonators be the answer to my problems. My car seems to be overheatin or seems to be alot "warmer" then others. Could that be a problem? Some of you may have heard of my problems. But when I am on the freeway and give it a good push of the throttle...maybe up to redline so it shifts on its on...I'll get to about 100 and then slow down...then I'll try it again after about 2 minutes later and the car will downshift and all but the car feels like the s/c isn't engaged. The rpms go up but the "in your seat" action isn't there? Any suggestions??? Please help!~!
Old Oct 14, 2004 | 03:50 AM
The Godfather's Avatar
4 wheeled car.
I doubt that the resonators affect your car's performance. Aren't the resonators there only to muffle the sound of the exhaust? Perhaps it plays a part in backpressure, but I would think that there's some issue w/ your S/C or something else, causing it not to engage.
Old Oct 14, 2004 | 05:10 AM
D-5's Avatar
D-5
2003 E55
could it be a water pump failure? ...I'm taking a wild guess
Old Oct 14, 2004 | 10:47 AM
Vadim @ evosport's Avatar
C32 AMG
This is what now becoming "classic" intercooler pump failure. Pump shut-off intermittently causing a rise in intake temperature. At 255F DME shut-off the kompressor. Once pump comes back to life, everything is normal again.
Old Oct 14, 2004 | 11:38 AM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
That sounds very likely.
Old Oct 14, 2004 | 12:33 PM
BenzoBoi's Avatar
Super Moderator
W221
Is there any fix to this???
Old Oct 14, 2004 | 03:43 PM
TCM's Avatar
TCM
2001 BMW M5
The resonators do create some back pressure but nothing that would be the culprit of your symptoms.
