My 2005 e55 can't burn tires.
when I turn off the esp, I want to warm up the tires, but the motor does not pick up speed. which block is responsible for this?
Motor mounts could be shot.
R.K. |
Are you brake stalling?
Originally Posted by radride
(Post 8732700)
R.K. |
(Post 8732750)
Originally Posted by Alex e55
(Post 8732786)
I want to do a burnout. but the electronics won't let me do it
I hope you have some spare change for the potential damage to your car. Several videos out there when the E55 goes sideways and into the weeds. There was one fellow, I cannot recall his handle, that had a drift car that he custom built. If you search you might find it. Hopefully, others will chime in on this thread. He had an awesome drift car and he put a lot of time and effort into it. |
Can e55's get tcu tunes to help do burnouts?
2005-2006 won't allow burnouts. 2003-2004 will. Something was changed in the ESP programming on those later years. Do a search, this has been covered before.
(Post 8732983)
https://cimg6.ibsrv.net/gimg/www.mbw...70a77e7d45.png |
Originally Posted by bbirdwell
(Post 8732946)
You have to put the car in Dyno mode. Search and you will be rewarded.
(Post 8732946)
(Post 8733086)
no, it's not convenient for me in dyno mode. I need to warm up the half-slicks before starting.
dyno mode is the only way. |
Originally Posted by Hrvstr1
(Post 8733171)
I think it's TCU related. Do you have the stock transmission control unit?
Originally Posted by UncleBenz55
(Post 8733177)
Originally Posted by E55Greasemonkey
(Post 8733005)
Then in this case I would look for dead horses.
Alex are you using the ESP off switch?
My '01 E55 can't stop burning tires and breaking loose... any suggestions?
(Post 8734144)
(Post 8732946)
I hope you have some spare change for the potential damage to your car. Several videos out there when the E55 goes sideways and into the weeds. There was one fellow, I cannot recall his handle, that had a drift car that he custom built. If you search you might find it. Hopefully, others will chime in on this thread. He had an awesome drift car and he put a lot of time and effort into it. One morning, on my way to work, it wasn’t raining but the roads were relatively wet. I was sitting at a stop light and as soon as the light turned green, I slowly rolled into the gas and started to roll into it harder. At about 3500 rpm, the rear wheels completely gave and my car did a full U turn into the opposite lane of traffic. Luckily there was no barrier in the middle of the road or cars coming. Managed to counter steer and didn’t slide into the curb. Man, that was embarrassing. |
(Post 8732551)
Originally Posted by Diablo_CLS55
(Post 8734404)
I have not tested this with working ESP, however tomorrow morning I will turn ESP off and try it. Because my E550 wouldn’t burn tires either with ESP off. Didn’t seem like a lack of power but rather the electronics were preventing it from doing so.
Curious on the desire to do burnouts. Is this a drag strip reason o warm up tires before a run? .
Hmmm.... I never had issues painting stripe in my ratty ‘06 E55. Turn the fun police off and be careful to not throw the car away.
| All times are GMT -4. The time now is 05:52 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
