Trick to getting to Dynometer mode.
Old Oct 29, 2004 | 12:15 PM
draggingcents2's Avatar
2005 E55
Last week the Car and Drive artical was posted on the SLK 350 and how to put it into Dyno mode. I tried it last week many time and it did not work. I took car to deal to have the Brake recall done and ask about any new flashes for the ECU? I was told yes there is a new flash.
I picked car up and found that I now have the DYNOmeter modes. SO if it does not work on your cars then go to dealer for the lastest flash. And get the brake recall done as well.
Old Oct 29, 2004 | 12:17 PM
BenzoBoi's Avatar
Super Moderator
W221
Would you mind going over exactly how it is done? Thanks in advance...
Old Oct 29, 2004 | 12:46 PM
2005 E55
With new flash it is easy. ONCE again it did not work last week and not until I got the updated software from dealer. Maybe there for new 05 E55.
Key in possition #1 (first click to right) push your odometer reset button 3 times. then use the wheel arrows on left side and Arrrow up 2-3 times until you see Dynometer screen the use the right side arrows to arrow up to ON that is all. Start car. Then Dynometer screen stays there and can be turned off easily.
Old Oct 29, 2004 | 01:25 PM
BenzoBoi's Avatar
Super Moderator
W221
Thanks for the tip...
Old Oct 29, 2004 | 05:56 PM
zdkdeeier493's Avatar
What exactly is Dynometer mode? Does it just completely disable ESP?
Old Oct 29, 2004 | 06:24 PM
2005 E55
I tried it and car was not noticably fast? ABS is off. Traction control is off. and the prebraking when you lift foot off pedel fast is off.
What is the ride height of your cars in the 3 different settings? comfort mode, sport 1, and sport 2 modes?
My car in sport 2 modes I can fit 3 finger between wheel and fender. This never changes?? When I first got I know I could only fit 1 finger.
Old Dec 9, 2004 | 10:05 PM
Sorry to bring back an old thread, but I still can't figure this out. I went to the dealer for the brake recall a WHILE ago and was told that AMG vechicles do not get flashed. Also, I have heard that if you hold the ESP button down, it completely disables ESP...doesn't work. Any help on this?
Old Dec 9, 2004 | 11:19 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
I noticed that the disable button just gave you a longer leash but still wasn't deactivated. Marcus was able to bypass traction control but putting it in dyno mode. Here are several threads about this. I tried the C and D recipe on my 05 and it worked without flashing the ECU.
Check these links for details:
https://mbworld.org/forums/showthrea...573#post854573
https://mbworld.org/forums/showthrea...169#post904169
http://www.caranddriver.com/article....&page_number=2
Old Dec 9, 2004 | 11:30 PM
Vetluver's Avatar
Draggin,
Are you sure that you weren't iust spinning your tires? When I tried Dyno mode I had a severe problem with traction especially after shifting into 2nd. It felt slower because it was just shredding the Contis.
Old Dec 10, 2004 | 02:02 AM
Thanks!
Old Dec 10, 2004 | 07:53 AM
DerekFSU's Avatar
Getting in dyno mode is pretty easy, now try to get it in a hurry! Dyno mode is the only way you can do a real burnout before a run. But I have not found a way to get back out of it so I could see how ESP does with my mods in the 1/4.
Old Dec 11, 2004 | 02:36 AM
tommaey's Avatar
2012 C63 Coupe Iridium Silver
dragging2cents don't tell me you've got your suspension raised and u don't even realise it
Old Dec 12, 2004 | 11:26 PM
DerekFSU's Avatar
Anyone do this yet and figure how to get back out of it?
