Issue with Das
Old Aug 14, 2023 | 10:30 AM
SICAMG's Avatar
2005 e55 AMG
Issue with Das
For a very long time I am unable to link up with my TCU or do any transmission control test's....shifter, adaptations, actual values and so on. DAS will tell me "unable to initialize connection".
It will say "possible issues could be circuit 87" failure, wherever that is ...central gateway I thought but I would think if there was a circuit issue there would be transmission shifting issues.
I can get into everything else engine wise and do whatever I want but nothing with the transmission. Tried 4 different TCU's to no avail.
There are no issues with driving or anything else just no ability to link into TRANSMISSION with DAS.
I know some day I will need to link in LOL Any ideas ??
I would pop in a new gateway module, since it needs one anyway,but I have never programmed a module in this car before so I want to make sure I don't have an issue and learn the procedure before I start.
Old Aug 14, 2023 | 04:00 PM
Rune's Avatar
E55, 2006
Could it be a loose connection between the DAS and the OBD2 connector? Maybe the TCU uses a pin that does not make proper contact? I know I have that issue on occasion with my DAS setup, if the connector is fully in, it will not communicate.
Old Aug 14, 2023 | 04:32 PM
SICAMG's Avatar
2005 e55 AMG
No it's connected correctly as I have tried MANY times. I believe it is the Central Gateway module as per the recommendation from my TCU tuner.
Just have to figure out the programming so I don't create other issues LOL
Old Aug 16, 2023 | 04:21 PM
SICAMG's Avatar
2005 e55 AMG
OK so now it's really interesting. It's my DAS system that will not communicate. I bought a new Central Gateway Module to reprogram and I couldnt get in. Then I tried everything Body wise and could not get into anything except engine parameters. So I linked up with my Icarsoft computer and was able to link to every single module. My DAS system may have crapped out and Im guessing the multiplexer is the issue. This sucks. Now I have to find one.
Old Aug 16, 2023 | 08:51 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Have you updated your software RS232/422 drivers? That was the issue with my computer.
Old Aug 16, 2023 | 08:59 PM
SICAMG's Avatar
2005 e55 AMG
No I have not and have no idea how to do that. Also why would it just stop working since nothing has changed with the computer system at all.
The computer tends to do what it wants as well,strange.
Old Aug 24, 2023 | 06:40 PM
SICAMG's Avatar
2005 e55 AMG
Anyone need a xentry system for parts?
Old Dec 6, 2023 | 04:32 PM
SICAMG's Avatar
2005 e55 AMG
TTT
Not sure if the multiplexer is bad or the laptop. Will link in but does not read transmission stuff. $125.00 shipped
Old Dec 6, 2023 | 05:28 PM
MJBelcher500's Avatar
2006 E55
Originally Posted by SICAMG
TTT
Not sure if the multiplexer is bad or the laptop. Will link in but does not read transmission stuff. $100.00 shipped
Is that just the main unit or does it have cables?
Old Dec 7, 2023 | 06:53 PM
SICAMG's Avatar
2005 e55 AMG
It's complete with cables. So my buddy cleaned it up and it will for sure link in and do diag stuff and engine reprogramming,throttle body,cooling fan and such but does not link to transmission which is very strange. Now im wondering if it's the car it self. Who knows as it is an old C3 system and not very fast.
Old Feb 25, 2024 | 10:11 AM
E63007's Avatar
07' E63
My setup too isn’t able to “reprogram” the Tranny, but it can seemingly monitor it while it’s in “Simulation mode” because I’ve done several Tranny Oil Changes where I’ve used DAS to measure Tranny Temp before installing the Oil Drain Bolt!
