SBC pedal count
Start xentry, go through multiple menus to your car's data then select:
Control units
Chassis
SBC sensotronic brake control
Development data (should be at the bottom of the page)
Actuations
Complete index of Actuations
Break: To only get the count, select “Bremsenzaehler (DF_GetBrLiveTime)”. This gives the total actuations to date. To reset the count, go to the next step. If only monitoring for maintenance purposes, back out of the program now using F1 key.
Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen
set ulNBR to 0, click F3
Bremsenzahler auf beliebigen Wert setzen
Lebensdauerzahler F neu berechenen und schreiben
log out of xentry
Do not turn off car.
drive for at least 10 minutes. (or let idle)
Control units
Chassis
Actuations
log out of xentry
Below is what he posted but in black font LOL:
Start engine. (Note: If you only are checking the total actuation count and not resetting the count, the engine does not need to be running.)
Control units
Chassis
Actuations
log out of xentry
R.K.
Thanks for fixing
Now I just have to find motor brushes for a spare I have just in case.
-Brake system actual values:
-Bremsenzaehler (DF_GetBrLiveTime) – 317,439
-Pump cycles (DJ_GetPmpCycle) – 11,849,100
-Estimated remaining pump life in % - 24.5% (DJ_GetPmpLD)
-Pretensioning pressure in reservoir – 72 Bar (72-102 optimal)
