Bumper fit issue w/PLM XL
Driver side lower bumper attach point
Passenger side lower bumper attach point
I also needed to clearance the bumper tabs that mount there to clear the cooler. It was a bit of a pain. If I knew this going in, I may not have installed it. The last thing was to use allen head bolts and turn them down on a lathe to get as much clearance as possible between the bolt head and cooler. Even with all that, the bolt head still touches the cooler on one side.
I literally just walked in to house and got done mounting the thing after making the decision to cut off, and sacrifice, the lower mounting tabs in the sake of getting the bumper cover on with no more headaches (for now at least). And it seems to fit just fine…. No play or looseness whatsoever. With the pinch clips on the cover/fender interface, four bolts near the headlights, and small amount of security from the bottom cover, I’ve justified the butchery. Now, to do it all over, I would not buy the XL (overkill for my appl), but the standard PLM IC instead as it’s 1/2” narrower, which would’ve been sufficient to then use the lower tabs on bumper. Deciding to hack my bumper cover wouldn’t have been this easy, but I happen to have a brand new factory one (big $$$) standing by ready to go to the paint shop, to replace the current cover which is broken in half beneath the the IC opening (it came that way when I bought it, but missed seeing on auction pics…).
Also, I started an email correspondence with PLM design guys about the difficulty I’ve had mounting an XL IC without doing serious mods to the IC and/or car. I’ll report back any nuggets they send my way. I’ve got to believe other folks have had difficulty as well. Or not - and the pics on forums and in videos, as can be expected, only tell part of the story. I know AMG Meister commented in his YT video about having to trim and fuss with fitment on his E55 when he installed an upgraded IC, and that was the standard one.
I was worried about the bumper sagging over time if I eliminated the tabs, so I wanted to make sure to use them.
If you hear anything useful from PLM please share.
