Sagging on rear driver side wheel but holding air.
Old Nov 5, 2023 | 04:31 PM
BilliStyx91's Avatar
2008 Cls 550 base model
The air spring was replaced in 2019 it looks like ( if this is a manufactured date im looking at on the airspring) so I'm thinking that's probably not the problem🤷‍♂️ but not 100%. It holds air but sits lower than the other three wheels. Also when I press the button to raise the car it raises but is still slightly lower than other wheels. Any ideas? Bad valve block maybe? I discounted the level sensor because if I understand correctly. The rear has one level sensor and only one side is effected.
Old Nov 5, 2023 | 07:07 PM
fruitsalt's Avatar
2003 E55 AMG
Were both bags in the rear replaced or only one side ?
Old Nov 5, 2023 | 07:26 PM
I don't know tbh I haven't removed the wheel from the otherside. Is there a reason it would be relevant?
Old Nov 5, 2023 | 07:37 PM
fruitsalt's Avatar
2003 E55 AMG
The bags are supposed to be replaced in pairs. I’ve seen difference between sides when only one side is replaced
Old Nov 5, 2023 | 09:25 PM
I'll have to check on that. In my mind the newer air spring would cause it to sit higher than the others though, is my reasoning off there?
Old Nov 6, 2023 | 12:20 PM
fruitsalt's Avatar
2003 E55 AMG
to my knowledge different manufacturers have different compressions and valvings. For example Ive experienced that the arnott rear air springs make the car sit about half an inch higher then the genuine Bilsteins do.
check to see if both air spring bags are they same, if they are the same then the vehicle probably needs an airmatic ride height calibration, which is currently what I am dealing with.
