Crankshaft pulley
Old Nov 11, 2023 | 11:52 PM
Slow_55's Avatar
E55 AMG
Crankshaft pulley
Hello! I have a 2005 e55 and I recently changed my alternator due to it going out. When I was done putting everything back together I was letting it idle for a bit and when I was checking out all the pulleys I noticed the crankshaft pulley was wobbling. At first I thought it was an optical illusion but realized it wasn’t after I read about other e55 owners having the same issue. I came on here to ask how long I could drive around with this issue or if I can at all. And if it does give out what would get damaged. Or is this a thing where it wouldn’t matter if I kept driving on it. The car doesn’t vibrate or act different at all. Thanks in advance
Old Nov 12, 2023 | 06:32 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
At low idle speeds, that is too be expected. Let someone give a little bit of throttle and check again.
I had mine replaced for peace of mind because I didnt trust it, same as you did. Replaced it with a new OE pulley and it did exactly the same
