Vibration roughness when shifting.
First: Make sure you enough fluid is in the trans!
Second: You can always reset the trans adaptations. It will shift a bit harsh then but over time adapts to your driving style. Use a computer or the something like this method (see below)
Third: Trans mount (+ engine mounts) need replacement
This is where it registers which is low, but if its standing for a while it registers even lower
This is how much sticks out.
When the engine is not running I see that the level is higher.
Sounds like you have a converter chatter when it locks up. If it was a clutch pack you would get the MIL light on showing a fault but just guessing.
You really need to give a much more accurate definition of the problem ie: what gear,what speed,is it there when your to the floor with throttle.......
fundamental question about transmission oil measurement - Do i measure after switching the engine off? because thats when i actually see the oil level even register.
