Removing Air Strut Harness
Hi everyone, been running around with a y52y2 code for an open circuit on the passenger side for a bit. I found a video with someone who was having a similar issue but with a GL class. TLDR the issue was the harness that mounts to the side of the air strut. The issue I’m having is taking off the harness that’s mounted to the top and bottom of a cylinder that I’m fairly sure is welded to the air strut. The dust cover basically sits on top of the harness and I can not pull it off especially since there is a cavity in the harness that slots into the contacts on the cylinder (see replacement part below). Does anyone have experience removing this harness? If not can I remove the dust cover?
