105mm TB ISSUES
I've reached out to VRP with no response so far and Granatelli called and never heard of their TB's going on a Mercedes like this. They're willing to swap to verify not a bad TB but I don't think it's the issue. Has anyone found a workaround for the newer 13+ hellcat throttle body with the brushless motor?
Any insight is greatly appreciated.
I’ve double checked the stock and 82mm tb’s and they both work the same way 680-1480 ohms through the sweep and essentially inverted for other sensor. The brushless motor just sits at 80-84 ohms for both sensors no matter position.
My question is, is there anyway to make this work with the stock m.e.? Or am I switching to an old style BBK or Arrington with the oem brush motor?
To add to this, are there any other good tb options?
Sometimes car will run and drive with zero issues but then others it’ll act up 5 times in 5 miles. It always occurs when off throttle and has happened sitting still at a light and on decel while driving. During the fault my ndash logs show throttle position at 5 like at idle regardless of pedal position. Acc pedal sensors all sweep within values.
I made a new harness today using factory pins to rule out pin tension etc. and will monitor.
Malfunction still occurred with new harness and with a test file from Jerry at Eurocharged ( who’s service is awesome btw)
I finally broke down and bought a new factory mopar 92mm and have had zero issues so far.
Still on the 105mm tune and seems to be running a little leaner at times. Waiting on another update to help dial it in, but for now the 105 is going on the shelf until more promising results can be achieved.
I didn’t want to test a possible bad used one so I just got a new factory mopar 92. I believe by magneto-marelli? It was like $300 and bolted up to the 105 snout with a thin bead of mb black sealant.
Also there is two sensors the ECU is dealing with. One in the ECU itself that reads altitude which is a pressure type thingy and then the MAP sensor itself so between those two and the altered air flow at a different throttle blade opening from the larger throttle blade the ECU has a fit.....from what I have seen.
