Eurocharged stage 2 kit? (180mm rank pully)
From what I can tell, Eurocharged no longer makes this kit. Apparently it included a 180mm crank pully, tune, headers, and upgraded heat exchanger.
1. What kind of power did this kit make?
2. Was it fairly reliable?
3. It seems most kits today use a smaller "supercharger pully" to create more boost. I always heard this was "safer." However it seems Renntech used the larger crank pully in it's power kits which tells me it could be the way to go. But, won't a larger crank pully also spin the accessories (alternator, water pump, tandem pump, etc) faster resulting in faster wear on those components too?
