Check my logic : Both front struts leaking down?
So my logic is that the leak should be common to the front axle, which points me to the valve block : is my logic sound?
(What confuses me is that I thought there was an air solenoid for each strut, such that once it was filled, the air solenoid would not allow air to escape. I would have figure a leaking valve block would make it hard to pump car up, but not to cause leaks while sitting?)
