Code p0191 strange behaviour
Old Sep 23, 2024 | 09:47 PM
Merce63k2010's Avatar
Mercedes e63 2010
Hello I have mercedes e63 2010 I started to get this code after a couple days of tuning and modified the car full bolts on so the issue I'm having now power dropped first and second engine hesitates to start little bit and sometimes engine days I have replaced the fuel sensor just today and I will clean my injectors tomorrow morning I need help with this code should I replace the pcv valve also as well ? Last time I replaced it before 15000 kilo meters
Old Sep 24, 2024 | 10:18 AM
jimyj's Avatar
E320
The P0191 code indicates a problem with the fuel rail pressure sensor, which can be caused by several factors, especially after tuning and modifications. Since you've recently tuned the engine and made modifications, it's possible that the fuel pressure settings were altered beyond the sensor's optimal range, leading to inaccurate readings. Additionally, issues such as a failing fuel pump, a malfunctioning fuel pressure regulator, or clogged injectors could contribute to the symptoms you're experiencing like power drops and engine hesitation. Wiring problems, such as damaged or corroded connectors to the fuel pressure sensor, might also be disrupting the signal to the ECU. While replacing the fuel sensor is a good step, the PCV valve shouldn't be overlooked either, as a faulty PCV system can affect engine performance by disrupting the air-fuel mixture and crankcase pressure. You should probably run a full system scan. There should be fault codes on at least one or more control modules related to this. You'll either need to take it to a mechanic, but if you want to figure this out yourself, then you'll need to get a full system scanner. The youcanic full system scanner is very good at diagnosing all systems, and there are other scan tools that can do this. Just be careful to use a full system scanner or you may scan the car and see no fault codes as some scanners can read all vehicle systems. For your picture, it looks like you are just using a basic obd2 scanner which may not show all codes. I hope this helps, and feel free to reach out if you have more questions!
Old Sep 26, 2024 | 08:27 PM
Mercedes e63 2010
I did check my injectors and they were all fine and fuel rail with the sensor been changed and the wiring are all good .
yes im using a basic obd2 .
The question brother what's else left could possibly bring this code fuel pump or anything else also ?
