Misfire like symptoms at almost wot
Old Oct 24, 2024 | 05:22 PM
MartinWake's Avatar
CL55
Hey guys so my m113k is having this weird symptom.. if I go almost wot right before the click at the end as it's climbing up the rpms there's an obvious misfire. Sometimes it's little hiccups and sometimes it's constant. I recorded a video of it. It was doing it a lot in person but barely noticeable in the video. After 3k rpm it was just a constant misfire. It does not throw a check engine light which sucks because that would make this a lot easier... Any suggestions on what I could check thanks!
I have replaced the plugs in my ownership which is less then 10k miles also the only thing done is a tune which has been fine for 4 years now. Pulley is stock
https://www.youtube.com/shorts/wRLv1a1KXnE
Old Oct 24, 2024 | 07:36 PM
SICAMG's Avatar
2005 e55 AMG
Pull the plugs and check a few of them for any built up carbon.
Old Oct 24, 2024 | 10:51 PM
MartinWake's Avatar
CL55
if there is built up carbon is the solution a simple spark plug change?
Old Oct 25, 2024 | 08:10 PM
MartinWake's Avatar
CL55
found the problem... when i took my car to do the valve covers it seems like they didn't plug in the coil to the spark plug all the way..
