Oil Level in Cluster
Old Apr 29, 2025 | 07:15 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
So I been dicking around with my Autel and clearly have removed some functionality in the Ins Cluster. Case in point is I cannot check the oil level anymore.
Oil level is read via the Autel and the sensor works fine - just cannot see the Oil level Check in the cluster - also via the 3 button push method - nothing comes up re oil on that screen.
Got some dipsticks on order as I prefer that anyway but would be nice to have this working again.
There is an Instrument Cluster Oil Level config in the setup but does not change anything. The options are “switches” and “ sensor” and neither seem to do anything.
“Switches” weirdly appears to be the suggested setting.
Any advice ??
Old Apr 30, 2025 | 05:10 PM
stevebez's Avatar
Found a way to get the oil check back - need to run a IC reset after you have made any changes.
