CL65 wheels on a W211 E63?
I think I found a set of SL 65 wheels for sale and I want to make sure these are the right ones...
Front 8.5xJx19' H2 ET44 and Rear- 9.5X19; ET60
Will this be the ones that fit ideally on the W211?
For your reference, the front and rear offsets for your stock wheels are F-38mm and R-44mm. The front replacement wheels are only 6mm (about 1/4") difference and set in closer to the center of the car while turing the front wheels full left and right to make sure that is sufficient sapce of the wheel to be closer to the center. That 6mm may not be an issue as much as the rear wheels. But, again careful examination is needed for any of these to be considered. While you may have sufficinet room to move the wheel in 6mm (1/4") it would be much more a challenge being able to move the rear wheels toward the center 16mm (5/8") without having an issue. As previously mentioned a quality spacer in the raer (15mm) would bring the 60mm down to 45mm and get you where you need it to be - but then, you have spacers. I hope this is helpful.
