Smooth Running Data Messy
Old Sep 17, 2025 | 09:54 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Hi Guys
Trying to track down the smooth running of the E55 - live in cylinder observations bounce all over the shop on all cylinders with some up to +-6 , with the acceptable threshold supposed to be at +-3.5. This is regardless of when at idle (bumped up to 700rpm from 650) or when engine at 2k say - adjustments seem to be the same.
Also an odd one is the mixture adaptions on bank 1 ranges from 157 to 161 and on bank 2 from 1 to 3. I cant explain the difference between bank 1 and bank 2?
Caveats - Has a 180m Pulley, Wetterauer Tune (basically same as Kleeman), Kleeman Cams, Carbon intake with BMC filters and Kleeman style headers. No Primary Cats. Secondary O2's disabled. Stock exhaust otherwise, 35k miles.
I am thinking Injectors / Primary O2 sensors / Fuel filter ?
No specific codes thrown.
Old Sep 18, 2025 | 07:12 PM
bobgodd's Avatar
2004 E55
Originally Posted by stevebez
Hi Guys
I don't have any help for your question unfortunately, but curious about Wetterauer Tune. How would you classify them, remote tuner or something more in-depth? Their knowledge of the ECU?
Old Sep 19, 2025 | 01:54 PM
stevebez's Avatar
When I went to Kleemann to sort out the TCU tune for the 2.82 diff and dropped my car on their Dyno - the Wet tune made as much as their tune does. 613hp implied Crank HP. They were reasonably impressed I would say, Then again this was mbe 7 years back?!
Old Sep 29, 2025 | 05:04 AM
stevebez's Avatar
Was O2 sensors - replaced all 4 and we good to smooth running again.
