Airmatic Will Not Raise
Old Sep 18, 2025 | 08:07 PM
Morp's Avatar
2003 E55
I’m troubleshooting the Airmatic on my E55 and running into an issue where the car does not rise at all, even though the scanner shows pressure changes. After releasing all system pressure, I attempted to refill each corner. The left front starts around 1 bar, rises to about 4 bar, then drops back to ~2 bar. The right front starts at 3 bar, fills to about 6 bar, and holds. Both rears start around 3.5–3.7 bar and fill to about 5 bar.
All four fenders stay at about 24" from the ground, with no visible lift. It seems like the struts aren’t actually getting air, and I’m wondering if this points to a bad valve block, a blocked/leaking line, or something else.
Old Sep 18, 2025 | 10:10 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
https://mbworld.org/forums/e-class-w...ml#post9214672
