Chasing a annoying buzzing noise from my E55
I have replaced so far -
rocker cover through to throttle body breather pipes
Drivers side rocker cover gasket and breather cover
disconnected the secondary air pump as I was told by many people it was that. No change.
passenger side surge tank gasket (drivers side i’ll do this week along with throttle body gasket)
So other than the throttle body and drivers side surge tank gasket which I’m swapping out this week, if they don’t fix the issue what else should I be looking at? I’m new to doing mechanical bits myself but determined to fix it ahaha.
Also if it runs correctly and idles normal it should not be a leak anywhere since the MAP sensor would pick it up and then the ECU would have a fit and throw codes.
