2006 E55 AMG P0113 code
Old Nov 7, 2025 | 08:02 PM
Johnnyb46's Avatar
2007 cls 550
The P0113 code on a 2006 E55 AMG
indicates a problem with the Intake Air Temperature (IAT) sensor circuit, specifically a "high input" signal to the engine control module. This means the sensor is sending a voltage signal that is too high, which can cause the engine to run improperly. The issue is most commonly caused by a faulty IAT sensor or damaged wiring, but a contaminated sensor, detached connector, or shorted circuit are also possible causes. can anybody help with this
