2003 E55 AMG MOST LOOP OPEN
Old Feb 2, 2026 | 07:35 AM
dylanman's Avatar
2003 E55 AMG
I have recently bought a 2003 E55 and the radio has not been working since I bought it. The radio turns on and shows AMG logo but then turns off, I checked the codes and did some research and the Fibre optic loop is open but I cant find which part is causing the problem. I bought a Fibre optic bypass plug and have tested it in the CD changer, and the Navigation unit in the left side of the boot and none has fixed it. Im not sure the order in which the light goes through but i know that the light goes through the Head unit, CD changer and Navigation system. Im not sure what to check next.
When I first took the head unit out I accidentally pulled the wire out of the green connector which i'm not sure is necessary to fix because its not fibre optic
Also the previous owner had a Bluetooth adapter not sure if it was Mr12Volt or different brand but the power/ground wires were left disconnected and have corrosion on the end of the plug and the Fibre optic for the Adapter was left hanging which i plugged back into the CD changer.
Should I be disconnecting the battery and resetting it after checking each Component or would it not matter.
The codes I have are:
D100: Most Master reports open ring.
D117: Specified/ Actual configuration of Most ring differs.
I have access to a scan tool if that could help me locate which part is faulting.
Old Feb 2, 2026 | 07:43 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
See if the glass is passing light,
Amazon Amazon
Old Feb 9, 2026 | 01:53 AM
dylanman's Avatar
2003 E55 AMG
Originally Posted by OldManAndHisCar
I figured out the optic loop has been changed to add in another device so will have to rewire to original somehow
Old Feb 9, 2026 | 03:55 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Ah, the joy of trying to figure out what un-noted modifications were performed by a previous owner. That's why I document with photos all work I perform on my vehicles so as to entice a potential buyer.
Download the attachments and see if they assist.
