Cam Timing Question
Old Mar 20, 2026 | 09:26 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Cam Timing Question
So I was puling the engine apart to check it over and replace the front timing cover coolant seals and also checked the cam timing.
The left bank timing tool slotted in perfectly - but the right bank tool was off by 1-2mm to slotting in freely (looks like being out by 2-4deg). Now the way I understand this is the cams lock into the timing wheels in a fixed manner - i,e, the only way the timing could be off is if the guides have worn or the chain has stretched (or both). Find it a bit hard to believe on a 37k mile engine though - despite it being ~20years old.
Presumably this level of out of tolerance is unacceptable otherwise why make precision timing tools?
Anyone else face a similar situation?
File Type: mov
File Type: mov
Old Mar 22, 2026 | 12:07 PM
SICAMG's Avatar
2005 e55 AMG
Anything is possible. I would lean towards the chain being a little stretched. If you adjust the other cam to be 1 degree out ,than the other side should be 1 degree out as well so that would tell you its a chain and over all it is really not that bad.
Old Mar 22, 2026 | 05:08 PM
stevebez's Avatar
Had smooth running a bit messy and over spec … thinking it was this - but pulling timing cover and change the coolant seals - will check chain and guides at same time.
Old Mar 22, 2026 | 05:58 PM
SICAMG's Avatar
2005 e55 AMG
If you get a chain make sure you get one that is already linked togather. Some have to have the special,of course, tool to connect the end links togather.
