Does the battery control module need coding?
Old Mar 23, 2026 | 11:23 PM
GokiePokie's Avatar
2006 E55 AMG
I have a 2006 E55 with the red battery light on. I scanned with xentry and have no communication to the battery control module. Merc no longer has these in stock so I ordered a used one from fleabay. Do I need to virginize/code the replacement?
Old Mar 24, 2026 | 06:10 AM
trigital's Avatar
W213 All-terrain
If it is chosen correctly, it does not need any coding.
Old Mar 24, 2026 | 08:06 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Try resetting the BCM first. Tech bulletin below.
Old Mar 24, 2026 | 10:09 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
what is a circuit 30 reset
Old Mar 25, 2026 | 11:48 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Circuit 30 is constant power. You are disconnecting the BCM from its constant power supply; sort of like a "hard" reboot on a computer.
Circuit 15 is switched power; there are several subcircuits (e.g. circuit 15R) that activate in sequence as the system comes online.
Old Mar 25, 2026 | 05:21 PM
Sulaco's Avatar
so circuit 30 reset is just disconnecting both batteries for a few minutes?
Old Mar 25, 2026 | 09:13 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Correct.
Errata; Circuit 30 is unfused; direct connection between battery and module (alternator). Circuit 30U is fused; direct connection to the battery but with a fuse inline (starter motor on some models). The latter is primarily the diesel versions of the W211 which use a 250 amp fuse in the harness. The schematics for the W211 E55 (U137 - applicable to the M112 and M113 engines) do not show a fuse inline. So...multiple versions of the schematics depending upon version and always fun (not!) to work through trying to understand the circuitry.
