Keepers stuck in retainer?!!
Old May 8, 2026 | 03:31 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
So managed to do twenty valve seals but bank one exhaust is a no go. I cannot get to them with the Lisle tool - which is great btw - but you need to give it a good wack - no way you pushing these valves down.
Now cannot access the exhaust valves using this tool and using a leverage arm style to try and unseat the keepers but with 8bar cyl pressure not enough to break them away. I beat on it as much as I dare - wiggled it - a LITTLE heat, penetrating oil etc … rope inside cyl … no dice. Somehow bank 2 was way easier 🤷‍♂️
So any bright ideas on how to get around this?
Old valve seals were pretty hard fwiw - and cannot let these 4 valves get a bye.
TIA
Old May 8, 2026 | 08:43 PM
SICAMG's Avatar
2005 e55 AMG
When I have done it I would put a socket over every retainer and give it a good shot. This will free the keeper and retainer, then I would remove the retainer with the compressing tool.
Old May 9, 2026 | 03:28 AM
stevebez's Avatar
Yep this is what I did for the valves that can be accessed with a blow hammer but the exhaust valves are so close to the frame there is
so little access to get to it with a clean and vertical blow… intake valves were a doddle.
Old May 9, 2026 | 05:07 AM
SICAMG's Avatar
2005 e55 AMG
OK you can try this. Bring the piston up to top dead center so that the valve will hit then push down on the retainer. You will not damage anything and I have done this many times in your same situation. Unorthadox but works well. The keepers just have a good bite on the retainers. As a matter of fact we have done all cyliders with out air pressure this way and it's impossible to drop a valve.
Old May 9, 2026 | 05:33 AM
stevebez's Avatar
Geezuz - I am so stupid … that worked a charm. More finesse and less force!!
Thanks!
Old May 9, 2026 | 05:50 AM
stevebez's Avatar
Old May 9, 2026 | 08:01 AM
SICAMG's Avatar
2005 e55 AMG
Good to hear !!
