Merry Christmas....NOW HELLLPPPPP!!!!
2003 E55 & 2014 GL550
Boought myself a tiny Christmas present of K & N's for the 55 and they slip on no problem at all.
THE LAST F'IN BOLT IN THE BACK ON RIGHT ....AND DROP THE SCREWDRIVER DOWN ONTO THE TRANNY....SHE RATTLES AROUND A LITTLE AND....GONE. SHINING THE FLASHLIGHT AROUND FOR 30 MINS....CAN'T SEE IT...NOT UNDERNEATH. JACK IT UP AND SLID A LITTLE UNDERNEATH....STILL CAN'T SEE.
EVEN RESORTED TO STARTING IT AND ROLLING BACK AND FORTH A LITTLE TO SEE IF I COULD GET HER WIGGLE OUT OF HER LITTLE HIDING SPOT....
WHAT THE HELL DO I DO?? IS IT EASY TO TAKE THE BOTTOM PLATE OFF...MIGHT HAVE TO DO THAT...
ANY IDEAS....OY...WHAT A DAY
MERRY FRIGGIN CHRISTMAS.
2005 E55 AMG
I keep a telescoping magnetized pickup tool - available at any parts store - for just such emergencies. Too bad they prolly won't be open until Sunday AM. Wait until you can get it in natural daylight to get a better view.
BTW, if you're sliding under the car, hope you've got jackstands set!
SL 65 AMG and E63s AMG
Do you have a friend who is a urologist? or a pulmonologist? I have an old worn out flexible cystoscope that I use to stick into tight places to get things out. It is invaluable.
I helped my friend who is a ASE mechanic do a washerectory on a 911 turbo. Saved a lot on time not having to pull the intake.
As long as it is ferrous material a magnet will work. I have resorted to putting double sided tape onto a flexible grabber that I got at Autozone also.
Another trick is to improvise a dental mirror then use an extremely bright light. LED or halogen from another direction can help locate the part.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Found it!! Had to pull the plastic plate off the bottom which wasn't all that bad. Just 5 or 6 bolts. Then slide alllll the way underneath and peak around and there she was.
Thanks for the info.
Getting the drag radials on next week....should be fun.
Here's to a twin turbo 2005!!!!
