LED license plates
Old Oct 13, 2010 | 07:57 PM
way2evil's Avatar
1989 Toyota Tercel Coupé
LED license plates
So who has done this? How do you get that black panel out from the back above the license plate?
Old Oct 18, 2010 | 03:18 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
If there's no screws, maybe it pops off?
Old Oct 18, 2010 | 10:17 AM
way2evil's Avatar
I can get the ends to pop off but the middle piece where the handle is I cant get to come off.
Old Oct 18, 2010 | 10:31 AM
Vic55's Avatar
Administrator
Originally Posted by vtecsti
1. Remove the two covers on the oem license plate lights(phillips head).
2. Remove the trunk carpet.
3. Remove the plastic piece around the trunk latch(requires a torx wrench or screwdriver set.)
4. Remove the license plate. There is a screw behind it with a rounded off head. You have to use a 5/16" nut driver from the inside(gold nut). One that comes off, you can pop the outside panel off. Just be very careful not to bend it too much. It could crack the paint. Once that panel is off, it's cake. The hardest part once it's all apart is pushing on the tabs on the existing housings to remove them. It takes some elbow grease, but they should come right out.
That's basically it. It was only difficult when I didn't realize the trunk panel came off. One I got that off, it was a walk in the park.
From the W211 section.
