18" for winter?
Old Oct 24, 2011 | 01:55 PM
Mtl20v's Avatar
2013 E350 4M, 997 Turbo, MK3 GTI
18" for winter?
Are any of you running 18" on your E63s?
Old Oct 24, 2011 | 02:31 PM
hyperion667's Avatar
2012 CLS63
just moved up to 19's....
of course we get inches in NC....not FEET, or better yet...not YARDS of snow....
I do have them on my 550 4 matic however....
Old Oct 24, 2011 | 04:43 PM
e550 87ss's Avatar
E63, E90
Plan on upgrading to 20s and using the stock 18s with some blizzaks. I don't think the brakes will allow for smaller diameter wheels... If you go aftermarket get the smallest width wheels 18x8 or 7.5 if possible. I've seen people run 19s with winters without a problem...
Old Oct 24, 2011 | 04:59 PM
steven1888's Avatar
2008 c350 sport
Size doesn't matter lmao.. At long as you get some good winter tires.. And not anything else.
Old Oct 24, 2011 | 07:59 PM
e550 87ss's Avatar
E63, E90
Diameter certainly does matter, it determines the amount of profile your tire/rim/car can have without rubbing. Running 20s on low profile tires in the winter with less sidewall can lead to cracking the rim against ice or thick snow... In addition during the winter roads will deteriorate and cracks in the road or potholes will form creating more risk for a bent or cracked rim or bubble in your tire.
In addition the financial aspect of purchasing larger diameter wheels and tires may also be a factor for some. I run 17x7.5 225/45 on my winter car (summer setup is 19x8.5 and 19x9.5) and still managed to crack a rim with a 45 profile tire... The goal for winter tire/wheels is smaller width and higher profile...
Old Oct 24, 2011 | 09:30 PM
steven1888's Avatar
2008 c350 sport
The goal for winter tire/wheels is smaller width and higher profile.. agree!!! sorry i was reference to the the rim size.. i misunderstood.
Old Oct 28, 2011 | 01:53 AM
darklord's Avatar
2011 E63
Any suggestions for rim/tire packages? Tirerack doesn't seem to have any online.
