Jerky acceleration
What I have found that helps is, if I start it up and then rev the engine once in park mode and then drive off, there isn't much of any issue. I'm thinking maybe there is hot exhaust lingering in the chamber that's causing this? No idea. Wondering if any of you out there may know.
i think if i go into S or s plus right away with engine cold and try to drive hard, it gets jerky in the 1, and 2 gears, i have to let off gas
Have you checked what the engine oil and water temps are when you take off?
