RACE START
Old Dec 13, 2013 | 05:20 PM
yad's Avatar
yad
2014 E63S AMG
RACE START
This is the information I have on initiating RACE START. "The Race Start function delivers maximum dynamism: while the vehicle is at a standstill, the driver is able to activate SPORT Handling mode and press the brake pedal with his left foot. Having preselected the Race Start program using the rotary switch, a confirmation message comes up on the AMG central display. The driver then simply needs to confirm the Race Start function by pulling the "Up" shift paddle once, fully depressing the accelerator and taking his foot off the brake. The optimum start-up engine speed is set fully automatically and the E63 AMG accelerates away with flawless traction - all the way up to top speed, if so required. The driver does not need to shift gear manually; the AMG MCT transmission changes gear in lightning-fast shift time"
The problem is this, for whatever reason I have not been able to rotate the control knob to "R". Can anyone provide me with an insight to what I may be doing wrong? Thanks
Old Dec 13, 2013 | 05:27 PM
Chocofishez's Avatar
2014 E63 S
likely need to be up to temp. Oil temp, diff temp etc.
Old Dec 13, 2013 | 05:44 PM
TheOtherEric's Avatar
993, 2014 E63 Wagon
Soooooo many threads on this. Did you search?
Old Dec 13, 2013 | 05:49 PM
keyserS's Avatar
From: Llanfairpwllgwyngyllgogerychwyrndrobwllllantysiliogogogoch, TX
E63S wagon w212; GLC63; GLC300; 720S
http://bit.ly/1dy8xzi
Old Dec 13, 2013 | 06:42 PM
ced357's Avatar
C63 BS, 2011 SLS, 2014 CLS63-S
Make sure you are at a complete stop with wheels pointed straight. Also, like others said, oil temps must be at least 176.
Old Dec 13, 2013 | 11:22 PM
nstanford99's Avatar
Ferrari 488
wheel pointed straight, just did one tonight, make sure the gas pedal is allll the way down, or close to it, and your oil temps have to be right! Press the AMG button, the press the sport handling button
Old Dec 24, 2013 | 08:57 AM
sul683's Avatar
E63S 4matic
Fasten your seatbelt
Old Dec 24, 2013 | 04:33 PM
zibby43's Avatar
'20 GLC300 SUV
Make sure you are absolutely STANDING on the brake. If you do this you will easily be able to get the knob to turn to the RS position.
I gave this advice to a gentleman in the C63 forum and this solved his Race Start problems immediately.
Good luck.
Old Dec 24, 2013 | 05:45 PM
ced357's Avatar
I love RS and do it at least once a day
Old Dec 25, 2013 | 08:48 PM
6G Schnell's Avatar
2021 E63S and 2025 GT63
Don't leave home without it !
Old Dec 26, 2013 | 09:50 AM
emericr's Avatar
2021 Porsche TTS
Testing the limit of your clutch and transmission Hal
